Should A2337 output to external video with LCD panel removed?
tawnytim
As the title states, I've got a A2337 which powers up(chime, caps lock, etc) but I can't get it to output to external video(screen removed).
Do you have USB activity?
There may be a problem with thunderbolt connection.
I connected a USB flash drive which has an LED which blinks when it's being accessed. There was no blinking so I'd say there is no USB activity. Possible this device is *not* booted, despite the caps lock functioning correctly? What else can I check?
I found some damage to the video header on the bottom side of the board and also what looked like a small coil or resistor which was blown off one of its pads. I can't find a boardview and schematic though - 820-02899-A
I cleaned up the header and replaced the resistor but that didn't change anything. Still the startup chime, 20v, pulling about 1.5a, caps lock working, no video output, still no usb activity.
I have been meaning to order that tester - thank you for the link, I will order it this morning. I have other simple testers and yes, I have 5v output to USB.
You may have problems with USB communication.
That impede external video to work.
Tried PRAM reset?
I didn't know there was a PRAM reset on M1, or any apple silicon. There is? Just CMD-OPT-P-R like the intel macbooks?
