nate8organic
Does a smc bypass confirm that the smc is bad or can there be x other problems causing the smc to not work, I have a few boards that green light and charge a battery but i can only get the fan to spin with a smc by pass, i tried a couple smc chips already and no luck so far. i wanted to confirm that the smc is at fault so i can consider bad soldering and or a bad smc chip from the donors. don't want to through out good smc chips from a simple mistake. the board i'm working on has smc reset present.
thanks
Nate
thanks
Nate
