ytesfay80
This macbook had a bad keyboard but was booting and working fine. I removed the SSD to plug it into an OWC Envoy enclousure to make sure the data was fine and after I was done I simply unplugged the usb to the envoy instead of safely ejecting so I'm not sure if that caused this problem but now when I boot the ssd it stops around halfway and the screen goes black and shuts down.
Now when I check the disk utility with the SSD in the enclosure or in the Macbook the SSD won't mount even when I click the mount button in disk utility. I even tried to manually mount using command lines in the terminal but it would not mount.
I tried doing the first aid but it would fail and say to back up data if possible.
I'm not sure what else I could do to mount the drive. I attached images of the disk utility screen.
