[SOLVED]280-3437 no backlight.
MDY
280-3437 no backlight. Can see blinking folder
LCD backlight - 8.57V
Enable pin - 2.84V
PWM - 1.47V
SDA and SCL - 3.3V
All 6 return lines - 0.630 with red to ground
Already replaced 2 times LP8550 and tried 3 different working screens. Have no more ideas.
MDY
In this board the resistors are just next to the connector. And 0.630 means they go to the LP8550. Also go to lvds connector.
MDY
Yes, it was A5 ball bad trace. Now have backlight. Had do remove the chip to run a wire. Do you run the wire without removing the chip? And also this happend on Pro too?
There is no magic. On some board there is a small bit of trace you can scrape clean next to the chip on most boards you need to pull the chip
