[SOLVED]3208 found pulled pad, tons of connections, am I effed?
Rford
Working on a 3208. Found a broken off resistor (R5250), and ripped up pad (1). There are hundreds of things running to this one spot. Am I fucked? Could I bypass the location somehow by tying in somewhere else?
It simply goes to the power bus and a wire to any point where that is present will work. Also this resistor will not prevent the board from working.
