Small liquid damage on U7100.
PPDCIN_G3H had jumpy voltage 5V-11V.
R7180 on pin 1 was damaged, pad on board was burned out so I did jumper from pin 1 C7184.
Now I got only battery symbol on display.
Tested with:
- 2 DC boards
- 2x 85W genuine charger
- 1 65W genuine charger
- 2x new battery
Replaced U7100 same issue.
Without battery there is only light on charger. No fan spin.
PPBUS_G3H
- with charger 16V (with or without battery)
- without charger 6.5V (with flat batt), 7.1V (batt with 20% charge)
It won’t charge when battery is flat.
I connected battery with 20% and works fine, its charging battery as well but when battery is flat there is battery symbol on display.
U7100
17/18 3.4 ohms
27/28 20 ohms (There was a few million ohms before. Duke suggested in other post to check trace between R7121/22 and R7120 and there was not connected. Did jumper from pin 2 R7121 to pin 4 R7120 and pin 2 R7122 to pin 3 R7120).
Any ideas?
Tested with:
- 2 DC boards
- 2x new battery
PPBUS_G3H
U7100
17/18 3.4 ohms
Any ideas?
