[SOLVED]820-00165 - no green light
nelo1012
have a 820-00165 that had liquid damage on u7090 area,
I replaced everything visually damaged,
L7095
C7094
C7095
U7090
R7080
C7092
checked for continuity and it seems fine,
PPBUS_G3H is present,
PP3V42_G3H is present,
but still no green light, please help! thanks!
nelo1012
PPBUS_G3H - 8.18V
J9500 No damage there at all,
and the Magsafe and Flat cable are known good, also tested from other macs to make sure, and no luck
JohnB8812
8.18 volts on PPBUS means the SMC is not running. Voltage on SMC_RESET_L? If 3.4, either the ISL or SMC is likely bad.
nelo1012
SMC was the problem, but I just reflowed it and it worked, did not reball,
thank you for all the help, mark as solved!
