[SOLVED]820-00165 No PPBUS_G3H
smiba
Impossible to get 8.58V at L7130 but simultaneously 0V on PPBUS_G3H.
Are you sure the fuse is not blown or gone into high resistance?
JohnB8812
That’s what I’m saying!!! Checked for continuity at the fuse on both sides and got a beep. I literally don’t understand lmao it’a the weirdest thing!! Resistance to ground on PPBUS was like .8 so no short that I could find.
smiba
Resistance in Ohm on the fuse? Should be 0, if it detects any kind of resistance more then just touching your probes together it's dead
0.8Ohm to ground on PPBUS is definitely a short by the way. Inject voltage and find the source of the short.
Keep an eye on the temperature of the CPU because you can't inject more then 1.2V without having a chance of killing it when the CPU high MOSFET is shorting. If the CPU is not getting hot the short is somewhere else and you can increase the voltage further in case you reach the amparage limit
JohnB8812
Replaced the cap and the fuse and PPBUS is back and the machine turns on and boots into the OS! Mark as solved!
JohnB8812
I do have a question tho as to why the PPBUS_S5_HS caps blow? I've had two this week with the same kind of issue where a big cap blows curious as to why? Bad charger, surge?
Nah, the Chinese chargers will kill the ISL and current sense resistors before killing caps on PPBUS. It is just plain random cap failure.
