SOLVED - 820-00165 water damage PM_SLP_S4_L pulsing
jadao
This board has PPBUS_G3H, PP3V42_G3H and PPVRTC_G3H.
PP5V_S4RS3 is pulsing, ALL_SYS_PWRGD and CPU_VCORE as well.
It does'nt start in smc bypass mode.
PM_RSMRST_L, PM_PWRBTN_L, PM_BATLOW_L, PP3V_SUS are all present.
Replaced Bios just in case and checked all 22 resistors.
Checked U1950 and U1900 and they are ok
Water was near Bios, U8130 and U5800.
I don't know what to check anymore.
Did you try known good BIOS file, or just clean ME region?
Do you also get pulse at pin 3/U1950?
Try to reball SMC.
jadao
Yes I tried 100% known working bios coming right from a working board.
I do have pulse as well on pin3 U1950.
Will reflow/ultrasonic/reball smc and report back.
Thanks!
jadao
I give up on this one.
Reballed smc same, replaced it same again.
checked again u1900 u1950 and ultrasoniced the board.
Liquid damaged board is not always easy to fix.
Could be crap under some BGA, trace, or ball cracked.
A simple corroded resistor can cause the same issue.
jadao
You are so right.
After a fresh look this morning I found out an open trace on SPI_CS0_R_L,
R6120 was not anymore linked with R6110. All other trace were fine,
I had a test point still with gold color but with a tiny corrosion on the begining of the trace, barely noticeable, This was enough to kill the machine.
As always, thanks 2Informaticos.
