[SOLVED]820-00281 no power
rex1986
Hello,
i have a 820-00281 Board which won't turn on. I inspected the board and it doesn't have any corrosion or burned components. All fuses are ok! I mesured pp20v_usbc_xb_vbus. It has instead of 20V, only 5,2V. ppdcin_g3h also has 5,2v
ppvin_g3h_p3v3g3h 5,2v
ppdcin_g3h_chgr_r 5,2v
ppbus_g3h_r 0v
If you need any other values, please let me know.
Can anybody tell me how to find the faulty component ?
rex1986
Pin 3 ppvin_g3h_p3v3g3h 5,2v
Pin 1 ppdcin_g3h_chgr_r 5,2v
Pin 2 ppbus_g3h_r 0v
Charger is Brand new from apple store and plugged in.?
rex1986
l6900 0v and r6921 5,2v
for one moment it had the right values but after that, always the values i wrote bevore
So enable is present to U6903 and it is receiving power from D6902. I would actually expect 3V on R6921 so make sure you are measuring the correct thing.
rex1986
l7030 0V and TBA_AUX_DET 0,9V
Do you have any messenger? Otherwise we maybe need a few weeks to find the faulty component or IC:D
thx a lot!
What is the voltage on R7075? I'm starting to suspect a bad U7000.
My direct messenger is available for $100 an hour if you really insist.
