(SOLVED)820-00431-a 1led green no power no fan spin
lincev
hi all, I have this board, connect power led1 green, pulse power button anything...
PM_PWRBTN_L=3.38v pulse SMC_ONOFF_L down to 0.10v
PM_SLP_S4_L=3.28v pulse power button same voltage no change
PM_SLP_S3_L=3.28v
SMCBAD ? thanks for all
lincev
history all right until last week it turned off and did not turn back on.
u speak about PLT_RESET_L? PLT_RESET_L=0v with/out pulse
No, I meant L7110/30/50.
You've said to get pulse on PM_SLP_S3_L, so many coils should pulse.
Check what happens in SMC bypass.
lincev
nice I don't have pulse but I have short to ground
resistance L7110 REG_PHASE_CPUVCC1=2.5ohms scale 200
I doubt to be short.
You should compare with similar board.
Powerful CPUs have low resistance as normal.
lincev
I don't have another 2015 board, can we go another way?
I've seen no voltage at any time in L7110/30/50
Is it true that the coil resistance is normal 01.0 and they seem to be good
So I don't understand why there is continuity to ground
On L7100 I have voltage 1.9v increasing very slowly
"Powerful CPUs have low resistance as normal"
I meant resistance to ground!
Any other coils pulsing in rithm with PM_SLP_S3_L?
Just in case, change Q8450.
lincev
niceeeee !!! thanks thanks ! solved ! the problem is Q8450
I was able to get this IC from a MBP 2011 and everything was solved
thanks for all !! :)
