SOLVED: 820-02016 - Only 1 USB C port boosts to 20V and no USB activity on either
SoloHarty
got an M1 MacBook Air on the bench. Unit is extremely clean with no signs of a drop or liquid. Unit will power on as normal but will only charge NORMALLY from the USB C port closest to the user. the other port stays at 5V 0.3-0.4A and no cycling (CORRECTION - unit CHARGES at 5V3A when plugged into the port closest to the screen and unit is switched on).. both ports do not have USB activity when plugging something in. I have tried 2 new port flexes and I cannot see any short on the lines at all. What could I be missing?
Any help appreciated.
Compare diode mode readings around both CD3217 chips.
Start with their LDOs.
You should try to change the chip blocked on 5V anyway.
SoloHarty
SOLVED - Replaced both CD3217 chips and all functionality came back. Bit of a strange one as no liquid anywhere on the board.
SoloHarty
SCRATCH THAT: USB ports function fine for USB DRIVES only. Will not see a mouse, keyboard or customers MIDI devices but will see and boot my MacOS installer drives no problem.... This is in OS and also on Boot menu. strange
SoloHarty
OK DEFINITELY solved this time around. one of the lines from L500 was pulled to ground. Replaced CD3217 again and all is working as it should. Thanks for the help 2informaticos!
