Gmorb
So the issue started with slow charge.
pin 17/18 and 27/28 checked out so i decided to replace the isl but now i only get a green light no charge indication.
i checked the smc data line resistors and theyre fine
the board will run off the battery and charger but will shut off if the charger is plugged in and battery is removed.
also i can see the magsafes green light will start to flicker when the battery is plugged in.
also q7055 (i cant remember exact component number) the current sensing component for charge fluctuates between 11.7 to 11.9v on pad 5.
could this be a case of bad isl from donor board?
