[SOLVED] 820-2796 - No Backlight
Status
Not open for further replies.
menatwork
U9000
Pin 1 - LCD_IG_PWR_EN - 0v
Pin 2 - PP3V3_S5 - 3.30V
Pin 3 - PP3V3_S5 - 3.30v
Pin 4 - PP3V3_SW_LCD_UF - 0V
Pin 5 - PP3V3_SW_LCD_UF - 0V
Pin 6 - GND
menatwork
F8000:
8.38V
J9000:
Pin 01 - 0.16V
Pin 02 - 0
Pin 03 - 0
Pin 04 - 0
Pin 05 - 0
Pin 06 - 0.13V
Pin 07 - 0.11V
Pin 08 - 0.11V
Pin 09 - 0.11V
Pin 10 - 0.12V
Pin 11 - 0.12V
Pin 12 - 0
Pin 13 - 0
Pin 14 - 0
Pin 15 - 0
Pin 16 - 0
Pin 17 - 0
Pin 18 - 0
Pin 19 - 0
Pin 20 - 0
Pin 21 - 0
Pin 22 - 0
Pin 23 - 0
Pin 24 - 0
Pin 25 - 0
Pin 26 - 0
Pin 27 - 0
Pin 28 - 0
Pin 29 - 0
Pin 30 - 0.17V
Q9807
Pin 1 - GND
Pin 2 - BKLT_PLT_RST_L - 0V
Pin 3 - LCDBKLT_EN_L - - 8.03V
Pin 4 - LCDBKLT_DISABLE - 0.20V
Pin 5 - LCDBKLT_EN - 0V
Pin 6 - LCDBKLT_DISABLE - 0.22
Q9806:
Pin 1 - PPBUS_SW_LCDBKLT_PWR - 0V
Pin 2 - PPBUS_SW_LCDBKLT_PWR - 0V
Pin 3 - LCDBKLT_EN_DIV - 8.14V
Pin 4 - PPBUS_S0_LCDBKLT_FUSED - 8.38V
Pin 5 - PPBUS_SW_LCDBKLT_PWR - 0V
Pin 6 - PPBUS_SW_LCDBKLT_PWR - 0V
R9808:
300K
R9809
147K
U9000
menatwork
both assembly I installed earlier were bad , I installed New Assembly again and everything works fine now .
Thank you Guys for all advice.
bjf
Im not an engineer and I undestand 1.003 MΩ ( 1MΩ) :)
Just want to make a request that we try to understand what we don't understand before we make comments like this. Not a huge deal, but let's be good students here. I'm gonna go ahead and posit that if dukefawks says it doesn't make sense, it probably doesn't make sense. Diode mode doesn't measure resistance, it measures voltage drop to ground if the positive lead is on ground.
Status
