[solved]820-2850-a , unexpected shut down..... also when playing game
Status
Not open for further replies.
turbo
820-2850 board , some time it shut down it self or ... if you play game it will shut down.... is it any CAPS no good?
when c9560, is bad it produce some resistance and we get 1.3 v and problem.. in my case, its 1.5v which is perfect
I didn't know about the 1.3V. I have this value (1,3V) on c9560 I changed it but the same problem persist.
I have a similar problem with the same board, could you please measure and post values of :
r9589=
r9585=
r9571=
Thanks
Do keep in mind that output on the rail C9560 is on changes based on load, it has the ability to output multiple voltages.
wow change c9560, problem gone, but duke what exactly science behind this ! could you place explain, thanks
wow i had 2nd board, that is fixed too!!!! i use caps from a 2013 donner mac air board. high quality caps....newer too....
i think when gpu need high power (when play game etc) from that power rail ... caps cant hold too much power and gpu turned off whole system.... if we put more powerful caps this prob will never come back fro sure.... duke
what would be more powerful caps which can hold more current ?
Status
