[SOLVED]820-2850 crashes when running graphics test
arnonabuurs
I read up a bit on this issue and found that the issue is usually from a failure at C9560. I checked voltage there and get 1.57, should be 1.8v correct? I have replaced the IC with a larger 330 one, but I still get the same 1.57v. Could it be pulled down by a short in the GPU?
