[SOLVED]820-2879-B slow working
Status
Not open for further replies.
macfix
Hello Everybody
Working on liquid damaged around SMC. Cleaned and worked fine. 2 days after clean board trackpad start to jumping and machine too slow. but 1 hour later every things fine 2 hours later again same problem.
10 times worked ASD only one time see error at bottom other times everything is ok.
[01/23/17 03:15:53] Thermal Interface - Processor:processor0: TIM Test 75 percent GB (test #4) - TIM Test 75 percent GB
- Check that CPU heatsink is properly attached, using product spec theta dh + 75 percent guardband.
[03:16:22] ERROR - -47006 [Processor power error] -- TEST FAILED
[01/23/17 03:16:22] Processor: 0 (test #1) - Whetstone Test
- Concurrent whetstone floating point unit benchmark test
At Battery and charger nothing change
Trackpad replaced nothing change
Where can i check next step?
Probably still crap under SMC or corroded resistor. Either run EFI version of ASD in a loop till it catches the failing sensor or just pull the SMC and reball. Also inspect resistors around SMC for damage.
Oh and those errors you got from OS version of ASD can be ignored.
Status
