PP3V42_G3H = 3.4v
PPBUS_G3H =12.6v
PP3V3_S5 = 3.3v
PP0V9_S5 = .90v
The readings I take looking for solution for no PM_SLP_S3:
PP3V3_G3_RTC
r1920 , r1921 = 3.4v one side , 3.3v the other side of resistors
BIOS PINS= 1 , 3 = 3.3V 2 , 4 = 0V 5 , 6, 7, = 0V PIN 8 = 3.3V (U6100)
PM_SLP_S3_L = R7859 = 0V I REMOVE THIS RESISTOR LATER AND I INJECT 3.3V AND FAN DIDNT SPIN I DID THAT ON ANOTHER MODEL BEFORE WITH A SHORT ON THE CRYSTAL AND FAN SPINS WHEN INJECTING.
Also as soon as I plug the charger and get the green light PM_SLP_S3_L beeps on diode testing mode when I inject to enable de S0 rails also instead voltage I got 0v and beeps on diode testing mode.
THIS MACHINE WAS WATER DAMAGED ORIGINAL DAMAGE WAS LOCATED AT: R6905
Board was cleaning using 99% alcohol and ultrasonic cleaner but cheap kind , im still waiting for the crest.
I look also for red test points I didn't find anything reasonable to focus on that area.
ALSO U4650 was fried from some pins I replace it.
Any next steps that I can do?
PPBUS_G3H =12.6v
PP3V3_S5 = 3.3v
PP0V9_S5 = .90v
PP3V3_G3_RTC
