[SOLVED]820-2879 no backlight
Status
Not open for further replies.
Even with BKL_EN missing there should be 12.6v going through the circuit.
What voltage is on pin 4 of Q9706? Pin 3 of Q9706?
How do R9731 and R9715 look?
larossmann I don't have Q9706 on this board. But I suppose it is the same as Q9806.
Pin 3 12.22 volt
Pin 4 12.58 volt
I belive that means that it don't let power thru
Q9807
pin 5 3.3 volt
pin 2 0 volt
R9715 , R9731 looks good
This is weird cause that would mean PLT_RST is low. Check it somewhere else like R2891 or 92. If also low check resistance to ground on there.
You can remove R2891/92/93/94/95 and see if PCIE_RESET_L comes high again. Could be crap under firewire chip if it is still low after removing all that. Last thing to pull would be firewire chip. If it is still low after that the MCP will be dead and that would be the end.
i removed the five resistors but still get 0 volt
I accidently touched both pads where R2893 was located with my probe that caused backlight to light up!
Is U4100 firewire chip?
I found a note that i wrote a couple of months ago about this board and i just found it. Dont know if it matters but i meassured L2590 it should be 3.3 volt but it is 2.5 volt. is this power to the MCP?
2.5V is fine, depends if U2592 is fitted or not. This is a dead MCP not pulling up PLT_RST.
You could try to add a 100K pull up resistor to 3V3_S0 to PLT_RST, but no idea if stuff wil properly initialize like that.
Status
