[SOLVED]820-2879 No power green light ok no orange light
aurel476
PP3V42_G3H 3,405V
PPBUS_G3H 0,478V
R7021/22 9,8 ohm
R7005 20,3 ohm
R7010 9,32K
R7011 30,15K
R7052 0,1 ohm
R7051 2,4 ohm
17/18 of U7000 3 ohm
27/28 of U7000 20 ohm
R5087 297K (need 470K replaced same value 297K)
SMC_BC_ACOK line 294K
CHGR_ACIN 3,98/4,01V light fluctuation slow
CHGR_DCIN 16,75V
SMC_RESET_L 3,40V
SMC_BC_ACOK 3,24/3,21V
With good battery know,
i plugge charger (battery connected) green light switch off for 1seconde and return to green light no orange light bad smc ?
resistance to GND on PPBUS line 1,06M and decrease, resistance around U7200 area fine
board startup only if battery plugged with charger, ppbus at 10,95 with battery plugged
now replaced U7000 board startup without battery with ppbus 12,25V
but battery no charging and no orange light, no power from battery
PPBUS_G3H line battery only 10,80V
In diode mode, red probe to ground, black probe to pin 2 of R5280 , what do you get? Same for pin 2 of R5281.
Either the U7000 you put on is bad, The SMC is bad, or the battery indicator thing is bad. PPBUS_G3H being 12.25v means the SMC data line with the U7000 and the battery isn't working.
In diode mode pin 2 of R5280 0,551V and for pin 2 of R5281 0,537V
battery indicator not work when pressed, work from another good board know
