[SOLVED]820-2914-B Keyboard and trackpad works for 1 minute, closing and openong lid makes it works again
Status
Not open for further replies.
Beto_MFC
This board is driving me crazy. Anyone experienced this kind of problem? The keyboard and trackpad only works for some time, then i need to close the lid to bring it back.
Beto_MFC
Both keyboard and trackpad are good, they work for like a minute or a bit more then both stop. I close the lid and open they get back to work for more one minute.
Working for a minute would not confirm the trackpad is good. Disconnect it and see if the keyboard keeps working, fans will run high though.
You are sure this is not a GPU issue and confirmed that an USB mouse is still working?
Beto_MFC
External keyboard and mouse works fine. When trackpad is disconnected fans spin normally. Now keyboard and trackpad only working in the efi boot drive selector. This board got reballed but I can turn off dedicated gpu in efi using fedora/grub.
Beto_MFC
Other issue: Computer goes to sleep after few minutes even when is told not to in preferences. Bad firmware maybe?
Beto_MFC
Thanks for the input but my suspicion was right. Bad firmware, just installed Sierra on a test disk and it updated the firmware - problem gone.
Beto_MFC
Found corrosion near to the reed sensor. Cleaned and now it works perfectly. It also fixed blank screen, before the smc always thought the lid was closed so no image. Very strange cos it still showed a white screen. Fixed too anyway.
Status
