[SOLVED]820-2936-A Wont detect ANY hard drive
Hello, I have a late 2011 820-2936-A that will not detect any internal hard drive, It can boot from a usb and then work fine except it will not see the internal hard drive. I have tried 5 different cables and hard drives with no luck. Where should i start?
Gurmon
ok, then lets start by checking R4533 - 36.
Does U4510 get 1.5V on pin 6 ?
Also there are lots of shitty third party HDD flex cables . You tested one of your new ones in a known good laptop ?
Hmm, possibly missing 1V5_s0 completely. Is 1V5 present on L7770? Short to GND on this rail? Audio will be missing too if 1V5_s0 is not there.
No voltage is present on L7770. I checked and you are right, there is no audio also. I tried to test for a short to ground and did not detect one, To me it matched up with a known good board but i have never tested for a short to ground before so I'm not positive i did it right.
