This board is water damaged at spots like USB A and B circuitry including U4650 U4600. And top side near edges and battery connector. There is no rust, it seems something like coffee...
Keyboard lever connector is gone and Pin 1 PP3V3_S4 and Pin 2 GND of keyboard connector were physically touching each others, plastic melted...
It booted fine with internal HDD but keyboard and trackpad were not working.
Before replacing keyboard connector I just cleaned it and made sure pins 1 and 2 are not touching anymore, removed the short but it was still low 0.7V and found out the zero ohm R7803 on PP3V3_S4 blown up to 500kohm.
Replaced R7803, made sure same diode mode reading compared with other board and board powered up fine with trackpad working fluently but keyboard had some keys not working (arrows, caps lock and some others) shift keys and alt are working.
USB data filter L4610 was blown, I replaced it and now both usb ports are working.
My issues:
-Keyboard is missing some keys no caps lock (no green light on caps key
) no arrows and some others...
-USB A & B are working slow. It boots slowly from external HDD, partitions appear very slowly, ASD EFI take much more time to load but passes all sensors and boot rom tests. This behaviour is with keyboard plugged and unplugged.
Didn't ultrasonic yet the board, I am affraid something wrong with USB portion of PCH. I don't see something else common to USB A and B besides PCH.
Before starting to replace U4650 and U4600 or ultrasonic the board, is there something I can check before? Could keyboard connector cause this slowliness on USB port?
Thanks
My issues:
Thanks
