[SOLVED]820-2936 missing cpu core
MDY
This board power and has all rails except CPU core. On U7400 pin 1 is 0V
I lift R7974 and on both pins still 0V
Board has stable 3.3V, 1.5V, 12,57V, 1,05V, 1.8V.
No liquide damage. Customer told that happend when connect sound card throught the USB.
L7100 - also missing 0V; 25ohm to ground; Diode mode 0.03
PM_SLP_S3_L - 3.3V
PVCCSA_EN - 3.2V
U7100 vcc and vpcc - 5V
First I have to solve missing L7100 and then CPU core, right?
Gurmon
Usually when PPVCCSA_S0_CPU is missing you don't get fan spin or PP0V75_S0_DDRVTT.
I'd start with replacing U7100.
MDY
Macbook comes again.
This time I replaced
U7100
U7300
both chips are bad.
and works ok.
Customer told me this happend when connecting sound card throught the usb port and in several seconds macbook die.
Any idea what could be that problem? Customer use china ac adapter.
smiba
Anything can happen with those chargers, I've seen bad USB devices kill random ICs or causing board issues before as well though, so it could be....
If it works now I'd say its resolved, but definitely get the customer to stop using the shitty charger!
