[SOLVED]820-2936 no image
gadgetfix
L9004 was burnt out. pad was gone. run jumper c9015
now getting 3.28v on pin 2/3/4
also got 12.6v on 21/22
chime screen flashes white for like a split second. external has display.
gadgetfix
Backlight cannot be present with 12.6V on the backlight pins. Please confirm...
definately something there as its not 100% pitch black. its strange it turns on chimes white screen flash. then its just black.
EDIT: you right- 12.6v when sleeping but when boot and running 25.6v?
JohnB8812
If the screen is white then goes dark instantly, that sounds like an SMC_LID problem. Honestly post video of what it does that might help
gadgetfix
duke most are reading ~497 with the exception of pin 18 which is 0 i turn over to the over side and one of the probe points which connect to L9080 is completely corroded. could this be the issue? should i run a jumper from pin 18 to L9080?
