BMarden
Liquid Damaged 820-2936 no green light, no fan spin. I cleaned up corrosion around ISL6259 , LCDS connector, U5400 and Q5300, Q4262 was corroded and replaced from donor board, a few misc caps and resistors replaced due to corrosion (mostly around U5400 and Q5300).
Plugged back in and got Green light and Fan Spin, That means I am done right Louis?
I put the logic board back into chassis and ran ASD which failed with "SMC IO failed" on test Th1H.
I checked PPBUS_G3H and discovered its 12.2V. Reflowed the SMC and now PPBUS_G3H is 16V???
I removed F7040 so I could take some measurements around ISL6259 and MOSFETS without the 16V causing damage, but with F7040 removed PPBUS_G3H is 12.50V
Any thoughts anyone?
Thanks
Thanks
