[SOLVED]820-3115 asd EFI Failure
jgraffis
Ive got this board here 820-3115 that I've been working on, It had been water damaged pretty good. i had to replace a few components one of them being the smc. the machine now powers on and will boot into os, but fails ASD EFI test for the following...
sensor- current(ID0R) dc in--- reading above the high limit
sensor- voltage (VC0C) cpu vcore--- reading above high limit
sensor- voltage (VP0R) pbus --- reading above high limit
dc in on pin 1 of c5439 .27v (doesn't seem right)
cpu vcore on pin 1 of c5329 .825v
pbus on pin 1 of r5489 2.1v ( Doesn't seem right)
not really sure where to go from here. any ideas or is there something I'm just not seeing?
jgraffis
ok. replaced the SMC again with one i ordered off the internet. Still same issue. Could be that that one was bad also iguess. i had one come in yesterday with same issues (water damage, got it to boot to asd with same errors). Wondering if maybe something is not right with the trace on the data line for pbus?
jgraffis
Sorry took me a minute to get back to this project board. i checked for avref on u5010 pin1 and had .970v also checked pin8 to have .950v. so obvious issue there. i also checked the readings for the ASD failures to find. ID0R is running ar 6.311Amp instead of 4.6Amp, VP0R is running at 19.763v instead of 16v, and VC0C is reading at 3.205v instead of 1.7v.
I'm kinda lost as to which of these i go after first.
Well U5010 pin 8 needs to have 3V3. So either U5010 is bad or something is loading that rails down. Check resistance to GND on the rail and if not unusually low replace U5010. Else it could be one of the caps on that rails that is pulling it down.
jgraffis
yes the board does turn on but fails asd efi now for....
sensor voltage (vn0c)-- axg vcore sensor is reading above the high limit.
sensor value is reading at 2.55v when high limit is supposed to be no higher than 1.7v.
i found the short to ground on pin 2 of r7550. so not sure how it could be going high with a dead short to ground.
There is no short AXG is usually a pretty low value. Sensor is just R5339 straight into the SMC so if this is the only sensor failing look at R5339 or bad SMC. Measure actual voltage on AXG first of course.
jgraffis
Ok we got this one fixed. broken traces around the u5010 killed me on this one, but was a good lesson for me.
thanks for all the help duke. you can mark this one as problem solved.
