[SOLVED]820-3115 no green light but PPBUS and 3V42 present.
JohnB8812
This one has zero signs of liquid damage. PPBUS: 12.56 3V42: 3.42 volts. I checked both for shorts, but neither are shorted to ground. Tried known good DC in board and 85 watt no change. Q7080 has 18 volts on pins 1-3 and 4, so I assumed that might be the problem and replaced it. Still no change 18 volts on both gate and source. What do I check next? R7080 and R7081 measure correctly. This one I've been messing with for like 3 days so need help badly lol.
JohnB8812
I do have 12.56 volts I could have measured wrong tho had many boards today. 3V42 is 3.42 volts, tried known good MagSafe does same thing as one with machine, ACOK is normal 3.3 and adapter sense is present.
So ADAPTER_SENSE and SYS_ONEWIRE are both 3.4V? If so then remove U6900 and do a diode mode check on SYS_ONEWIRE, SMC is now suspect.
JohnB8812
Ok so ALL_SYS stays pretty low. However, I think I have a short on PP5V_S3 resistance to ground is really low like 6 ohms to ground. I'll inject voltage and see what heats up. Is it safe to inject a lot of voltage into this line?
JohnB8812
Tried alcohol but can't find any heat. Going to get freeze spray it seems like injecting 5 volts at 1 amp nothing seems to get warm at all and the alcohol does bubble anywhere
If you inject 5V there is 1A flowing. That means you are putting 5W into the board and something must absolutely get warm. Use face/lips for heat detection and expect to get burned ;)
JohnB8812
Haha ok I'm gonna try again Monday I wanna fix this first time finally getting a SMC correct and it was so awful lol
JohnB8812
Found it! Put 5 volts and 3 amps through it and either C6214 or C6213 were shorted so pulled both and short is gone! Got to put a lot back, but I will test once everything is back on the board.
JohnB8812
FAN FUCKING SPIN BABY. Now going to test and see if it chimes and all that and run ASD. Light goes from green to orange with battery plugged in tho :)
