Got a board in that someone had ripped the battery connector off of (or poorly removed it). No damage to the board itself, and I replaced the battery connector and all seemed well. After a few minutes, the fan ramped up and trackpad movement slowed. Ran ASD, and the board failed all kinds of sensor readings tests:
- SMC: 0x0 SMC Critical Sensor Check [FAILED] -- SMC is unable to read sensor
- THSP Thunderbolt Proximity [FAILED] -- SMC is unable to read sensor
- TM0P MLB Top Side [FAILED] -- SMC is unable to read sensor
- TW0P Airport Proximity [FAILED] -- SMC is unable to read sensor
- Tm0P Memory Proximity [FAILED] -- SMC is unable to read sensor
- Ts0P Trackpad Skin [FAILED] -- SMC is unable to read sensor
No liquid anywhere on the board, and none of those appear in the schematics, but the board is clean. Was testing board in my known-good test assembly, but tried it in my 2nd test assembly just in case, and it still fails the same tests. Known-good battery, known-good trackpad, known-good trackpad cable, known-good DC/IO board and known-good DC/IO cable.
Is this a failed SMC? Issues persist even with battery removed, so I don't think it's related to the new battery connected I installed.
All help appreciated, duke.
