[SOLVED]820-3437 macbook air missing half the led backlight
Gannons3
So I have a 3437 board that i replaced the led driver on, and now i have backlight, but only half the backlight is working, one half of the screen is normal brightness but the other half is darker, is this a bad led strip or did i solder on the chip incorrectly
aprendiz
Moderator
Ill go for a bad soldering if the display assembly is a known good, also measure led return resistors...
Gannons3
ill solder on a different chip when i get home i have no idea if the displays good or not and dont have a test screen, thank you
Measure all LED return lines on diode mode. Could also be a bad trace or resistor in those lines. Or a bad connector/cable/LCD
Gannons3
okay so now i put a new chip on, and the backlight is flickering, still only the half of the screen though
The return lines read open so it is either a bad trace/bad resistor or badly soldered LP8550. All return lines should read the same on diode mode.
Gannons3
for some reason im thinking not all the balls on the chip melted, cuz i fluxed it up and just heated the hell out of it and it kind flowed a little bit into place, now its working fine, thanks for the help guys
