[SOLVED]820-3437 - PPBUS_G3H is showing .OL on multimeter
Status
Not open for further replies.
jadao
Hi vaswaniraj,
Are you sure your voltmeter mode is not set to a lower range? Something like 0-5V?
Autorange? Check with a 9v battery and see if you still have OL.
vaswaniraj
Hi Jadao, Yes you were correct. My sincere apologies, I was not setting my range correctly. Instead of setting it to 00.00, I was setting it to 0.000 due to which any component that I was measuring I was getting .OL.
Ok so now PPBUS_G3H is present and PP3V42_G3H is also present.
Further troubleshooting steps please. I will be very honest, in my life I have never used a multimeter, I am sorry for the errors that I have doing so far. But after this I know that I will not make this kind of error.
vaswaniraj
Yes it was liquid damaged and the customer changed the keyboard and trackpad himself, after which it worked for almost 9 months and then it shut down on him.
vaswaniraj
Hi Duke, The voltage on L7560 = 3.33V
The voltage on L7520 = 0 V
I don't see any corrosion around U6100 and neither on U1950.
Is L7520 supposed to be 0V ?
Because from the schematics I see it, should have 5V.
Please advice.
vaswaniraj
Hi Duke, I looked over the complete board, but I don't see any corrosion. The only green corrosion is see is by the SD Card reader. Some of the probe points I see are dark red, few are green and most are yellowish. Would a ultrasonic clean help ?
vaswaniraj
Ok let me try giving a ultrasonic clean. Will get back to you.
Around how much time should i put it into the cleaner and at what temperature.
Please advice.
Raj.
vaswaniraj
Ok, Thanks Duke. But troubleshooting wise you don't see anything wrong ? I was watching one of the videos of Louis where he has mentioned that PP5V_S0 is not present and then the computer will not come on. I checked the voltage on U8180 and it shows 0 ( Zero Volts ) Do you think I am going in the right direction ? Please advice.
vaswaniraj
Hi Duke / Louis, I Ultrasonic the motherboard, the components are all clean and shiny, but still the fan does not spin. When I connect the logic power to the magsafe adapter, the light stays orange, but the fan does not come on. I checked the following rails and here are my findings.
PPBUS_G3H = 8.59 V
PP3V42_G3H = 3.33 V
PP5V_S5 = 5.02 V
PP5V_S0 = 0.00 V
PP5V_S4RS3 = 0.00 V
PPVRTC_G3H = 3.33 V
PPDCIN_G3H = 16.51 V
PPDCIN_G3H_ISOL = 16.51 V
From the above I see that I am missing the voltages on PP5V_S0 and PP5V_S4RS3.
How can I get the 5V on these power rails.
Is it because of the 5V rails as mentioned above having 0 V the computer is not coming on and the fan is not spinning.
Can you please help me with the further in troubleshooting.
Regards, Raj.
Could be anything. The usual suspects are U6100 and the resistors in the data lines, U1950 especially pin 8 and U1900.
vaswaniraj
Hi Duke, As per your advice I checked all the resistors in the data lines and none of them are short to ground. Where else should I look for troubleshooting. I even tried to watch some of the videos of Louis in relation to 82-3437, but still am unable to solve the motherboard and make it turn on. Please help me troubleshoot further. Louis, your interference is required, if you don't mind. Thanks Raj.
Status
