[SOLVED]820-3476 PPBUS low no power
Status
Not open for further replies.
aurel476
Thanks anyway, just a question not link with board.
Why cpu vcore never shorted I see many post you said not possible cpu vcore shorted have you explanation if not long please
Where did I say CPU Vcore is never shorted? It is common to have a low value of 2 Ohms there and that is then mistaken for a short.
aurel476
Board power on :) battery only chime and display ok batterie charge
replace isl and checked resistance area 17/18 3.4ohms and 27/28 20.1ohms and R7125 ok
tried another charger good same problem
no startup from charger tried short smc_onoff_l work on battery only
aurel476
60w
i put to trash all my 60w magsafe 2 (buy on ebay seem guenine apple logo but pretty sure this fucking fake charger chinese (exactly same design of genuine).
I bought charger from apple store everything work perfectly
I can't remember Sticky "stop using bullshit charger" not present on the forum for check if charger is genuine is smc_adapter_en 3.33V ?
SMC_ADAPTER_EN only will go high if the correct or higher wattage charger is connected. So this board works now?
I hope you bought a 85W charger as this is the only one you need for testing.
Status
