[SOLVED]820-3476 (s0 rails present but not turning on anymore)
Status
Not open for further replies.
ytesfay80
This board sent in because the fans were running on full blast after a water spill. I ran the efi diagnostics and it told me the trackpad cable was the issue so I replaced that and the machine was working fine a couple hours ago. I decided to clean the corrosion from the liquid damage which was only around the following areas.
Q8150/Q1930 (attached image)
R8158/59
Q7310 (very light and only on pin 1 side)
I just put some flux and heated the area to remove corrosion. I replaced R8152&R8158 because they looked burned on one side. After doing those repairs the board no longer turns on even though PP5V_S0 and PP3V3_S0 are present.
I measured R8167 and on Pin 1(PM_SLP_S3_BUF_L) there was 3.32v and Pin 2(ALL_SYS_PWRGD) there was 0.11v. I replaced Q8150 and U1930 since they were connected to ALL_SYS_PWRGD but that didn't change anything.
Update: I see a little corrosion on the C1924 side of the U1900 clock chip and C1924 looks slightly black on one side. Could that be causing this and should I go ahead and replace this?
Also I see U5110 has some corrosion on pin 1 but 3.4v was present on all pins except for pin 2. Pin 4 (SMC_MANUAL_RST_L) - 2.78v
There are many S0 voltages, not only 3/5V; and all required to keep high ALL_SYS_PWRGD.
So check which voltage is missing and fix that.
ytesfay80
PP1v05_s0 and PP1v5_s0 were both present. PPVCC_S0_CPU was measuring only 0.05v.
I replaced U1900 and C1924 but that didn't change anything. Is SMC_MANUAL_RESET_L being 2.78v an issue?
All of these measurements are without the keyboard, trackpad, or other external components plugged into the board.
Leave the CPU core voltage now.
Look at the voltages involved to generate ALL_SYS_PWRGD.
That signal is required in order to enable CPU core voltage.
ytesfay80
Okay I was measuring Q8150 and I was getting 0v on Pin 5. I traced it back to R8151 and found that its resistance was very high.
I replaced R8151 and now ALL_SYS_PWRGD is 0.29v instead of 0.11v. Pin 5 of Q8150 is now 1.03v.
ytesfay80
Okay so I replaced R8151 and R8156 after measuring their resistance and now the fan is back spinning and vcore is present.
Crazy how a couple of resistors can stop a machine from turning on.
Thanks. You can mark this as solved.
Status
