I repaired an 820-3662 with a damaged LVDS connector. No liquid, no other visible damage, nothing. Runs and passes ASD just fine, but fails the sensor group test, with the error "ERROR - -13006 [The SMC has marked this sensor not present] -- TEST FAILED". Webcam works, Bluetooth works, WiFi works, trackpad and keyboard work fine (and this is a test case assembly that I use for all 820-3662 boards, which do not fail this test, so I suspect the board). Since the board works fine, I may not worry about it, but I like to document all boards passing ASD via photo, and like them all to pass completely.
Is there any way to identify which sensor exactly is being seen as "not present"?
