SOLVED - 820-4924 dead
jadao
PPBUS_G3H: 12.56V PP5V_S5 5V PP3V3_S5: 3.3V PPVRTC_G3H: 3.3V normal green/orange magsafe light
No further power rails present.
U1900 seems ok, I can see 32KHz present, SMC_ONOFF_L, SMC_RESET_L present at 3.3V
Found a very small micro greenish spot near smc, cleaned it and reflowed SMC but nothing changes may need a replacement or reball.
Also, with SMC bypass all rails are present but no chime (CPU voltage is at 1.8V), witch may indicate a sensor or SMC issue.
Anything I could troubleshoot further before replacing SMC?
Thanks!
jadao
Thanks JohnB8812 and 2informaticos,
Didn't yet replaced smc.
Always using original 85W magsafe 2 for magsafe2 power jack boards.
Should had mention I've already checked isl6259 pin 17-18 and 27-28 they are normal 25,5V and 5,5V.
AVREF_SMC is present at 3,3V.
CHGR_A/BMON are 0.031V and 0.053V respectively.
"isl6259 pin 17-18 and 27-28 they are normal 25,5V and 5,5V."
I don't understand what this means...
Post basic signals for power on sequence in normal mode.
jadao
Sorry I was tired. I mean ohms instead of volts!
Resistance on ISL6259 pins 17/18 is 25,5 ohms and 5,5ohms on pins 27/28.
thanks
jadao
Hi, here are all values I noted.
PPDCIN_G3H 16,5V
PP3V42_G3H 3.42V
PPBUS_G3H 12,56V
PPVRTC_G3H 3.3V
PP5V_S5 5V
PM_SLP_S5_L is missing (0V) so S4, S3 and S0 versions of PP5V are 0V
PP3V3_S5 3.3V
PP3V3_SUS 3.3V
PP3V3_S4 0,446V
S4_PWR_EN is missing (0V) because of PM_SLP_S5 missing
PP3V3_S3 0,23V
=P3V3S3_EN is missing (0V) because of PM_SLP_S4_L missing
PP3V3_S0 2.02V (0,293 diode mode)
32KHz present at u1900
SMC_ONOFF_L 3.3V
SMC_RESET_L 3.3V
S5_PWRGD 3.4v
SMC_ADAPTER_EN 3.4V
PM_BATLOW_L 0.19V
PM_PWRBTN_L 3.4V
PM_SYSRST_L 2.09V
PCH_SRTCRST_L 3.3V
PCH_INTRUDER_L 3.058V
PCH_INTVRMEN 3.237V
RTC_RESET_L 3.328V
As I said earlier SMC bypass makes board to turn on with fan running high (no chime)
I see that PM_BATLOW value is not normal... Also the presence of 2.02V on PP3V3_S0.
Thanks!
See what happens without U8030.
Do you get any S3 voltage in normal mode in such case?
Check SMC_DCIN_VSENSE level.
Low PM_BATLOW_L blocks PCH to start.
If you have correct charger for sure, then could be SMC issue; change it, for test.
jadao
Without U8030 I had no S3 voltage.
SMC_DCIN_VSENSE voltage is 2,42V whitch looks ok according to the voltage divider.
Changed SMC and yes the board is back to life!
I am sure just a reball would have worked but I didn't bother, board is in immaculate condition with white indicators but still this little corrosion I saw was the only hint.
Thank you very much for your support.
