Hello there friends...
working on a 820-4924 liquid damaged board
got it cleaned so no visible signs on corrosion..
measuring around the board, appears to be getting 1.04v on pp5v_s0
s3 and s5 are there reading 5.10v
looking at u8080 is getting the input on pin 3 from s3 (5.10v) but the en signal seems to be low (around 2.7v)
on R8187 i get 3.29v on 1 and 2.7v on pin 2..
checking this resistor which should be 47k ohm is reading around 17k ohm when it's in circuit
when pulling it out of circuit it's reading correctly 47k so i put it back on..
tried also replacing u8080 form a donor board, but still getting the same issue..
short to ground around this area maybe?
any help would be greatly appreciated...
thank you...
thank you...
