[SOLVED]820-4924 no backlight
Status
Not open for further replies.
Yes I'm pretty new at this. No I haven't found an article for this specific issue:)
I tried this first with the board out and no LCD connected.. I assume this is the wrong way to test circuits so I connected the LCD panel.
Here is what I found and can you please assist me in sorting this out? one odd thing I found is that as I tested some pins on some Resistors etc. The voltage was slowly decreasing.
Thank you in advance,
Chris
U7700 pin 17 en 3.3v
F7700 12.58v
PPVIN_S0w_LCDBKLT_R pin 1 c7700 12.58V pin 2 12.78V
R7701 pin 1 12.59v Pin 2 12.48V
Q7700
Pin 1 10.2v and decreasing
Pin2 8.36 and decreasing
Pin3 12.49v
Pin4 12.59v
Pin5 7.62 decreasing
Pin67.02 decreasing
L7710 PIN 1 8.2V and decreasing PIN 2 8.1V Decreasing
PPVOUT_S0_LCDBKLT
J8300 Pin 1 12.5V
aprendiz
Moderator
Voltage on Pin 30??? If you use a flashlight , can you see any image???? have you tried whit a known good display assembly??
Cant believe I missed this reply.. been waiting.. Damn.
Yes the LCD is good. Can see the Apple Logo etc. HDMI port works also.
I had the original LCD and had a an image but no backlight. Now, With the board out of the case but plugged into the LCD I cant even see an image..
Pin 30 has 5.1V
I put the board back into the case and I have a no backlight scenario. There is video, just no backlight. with 5.1V at pin 30
With 5V on pin 30 there should be something on the LCD. What voltage is on pin 1? Only 2015 LCD assemblies will work on these boards, make sure you have the correct one.
no obvious corrosion. I see a very little bit at these 3 resistors
R7731 12.5v on pin 1 nothing on pin 2.. no voltage on either side of R7732..
R7731 Nothing..
R7732 150k Ohms
Looks like R7731 is bad
SMMRepair
That's only a 3% difference; if it's the same package, and will fit without issues, it should be fine as long as the original spec tolerance is 5%.
Damn... yea well without ordering 100 of them it's a challenge.. I wish Lewis sold a kit with the top 20 components..
ill just keep searching. Thank you for your help.
larossmann
I created one for the air and it got one sale. and six hours of assembly time. never again.
Try the 13.7k and see what happens.
Status
