G.Beard
Hello, I'm having trouble with no backlight. Screen shows an image with no entery sign.
Voltages:
0v on pin 1 eDP
5v pin 3 & 4 eDP
Q7700 Drain = 12v, Source = 0v (Q7700 test good, changed it anyway, no luck)
U7700 VDD pin 5 = 5v, VDDA pin 18 = 5v
Diode mode:
Measured open loop from pin 1 eDP to ground.
eDP pin 3 to 4 = 0.7v
D7710 = OK
Continuity test:
No shorts to ground found
Pin 1 to cathode D7710 = OK
Cathode D7710 to R7731 = OK
Anode D7710 to Q7700 source = OK
Only thing I can think is LP8548 / U7700 is bad?
Voltages:
0v on pin 1 eDP
5v pin 3 & 4 eDP
Diode mode:
D7710 = OK
Continuity test:
