SOLVED: A2485 020-02100 - Short on PP1V2_NAND0 20V 0A
it-solve
Removed LN430, short stays on the NAND side.
Injected 0.9V, sinks up to 1.3A and no heat signature on the board or SSDs.
No direct liquid. Some corrosion around CN139/125/147 caps as well as CT054
No other shorts
it-solve
PP1V2_NAND0 side of the coil is the one which has low resistance
I soldered a wire and pushing 1.2V. It pulls 5.2 and sinks it somewhere but no heat spots on either side of the board apart than the cable. That must be a dead short to the ground plate of PP1V2_NAND0?
it-solve
Located the issue to bad components around UN100. Thanks again.
Some references for future cases:
> PP1V2_NAND0 - 6Ohm
> P0V9_NAND0 - 100Ohm
