[SOLVED]Early 2013 13" MacBook Pro Fans running full speed. 820-3462
wrbailey
Machine turns on and chimes and will boot to desktop. Charges, etc... just fine.
This machine has the fans running full speed.
I've run ASD and I get these sensor errors:
TA0P -- Ambient Air Sensor (ERROR - SMC IO FAILED)
TA1P -- DC-IN Proximity for Airflow (ERROR - SMC IO FAILED)
TC0P -- CPU Proximity (ERROR - SMC IO FAILED)
TM0P -- DDR3 Proximity (ERROR - SMC IO FAILED)
TW0P -- AirPort Proximity (ERROR - SMC IO FAILED)
I have not been able to locate liquid damage (and I am the only one to take machine apart.)
Everything seems to run the way it should. It does not have an error on Ts0P for the trackpad, that test actually passes.
Is there a certain area of the board I should be focusing my efforts on?
Thank You!
wrbailey
Thank you for the reply. I will check these values once I am home in a few hours. The machine is in beautiful shape, would love to resurrect.
wrbailey
U5570 was just fine. Found some corrosion around Q7850 and the backlit keyboard connector. Cleaned up the areas and BAM, no more loud fan and passes ASD now. Not sure why it would cause the sensor issues?? Any idea? But this can be marked fixed (not so much solved, but fixed)
Thanks!
