[SOLVED]iPhone 6+ No Siri
Status
Not open for further replies.
So customer comes in with an iPhone 6 Plus Touch IC issue. I replaced the U2401 & 2402 which we have done many times. But now there the mic on siri does not work. I have changed the sensor/camera flex and still doesn't work. What could be the problem?
mohammed
Have you double checked the components near the ffc connector that are under the black glue junk? Usually those small components get loose
I'll try reflowing the audio codec chip(don't have in stock to replace). If not I'll order. Hopefully that solves the problem.
Status
