[SOLVED]Macbook Air 13 (820-00165) shitty logic board again Why WHY
Ciki
Now board was water damaged around U3220 ,cleaned ,replaced now when connect board with charger green light and orange but no spin PPBUS_G3H 8.5 V,PPVRTC 3.3V ,PP5V_S5 5V missing PP5V_S4RS3 ,now when I connect battery and charger macbook chime and start (working) once when started I can disconnect battery and its still will work ,so to turn on needs battery connected ?????
JohnB8812
Lol I literally had the same problem last week! If it recognizes, charges, and runs off of the battery, I'd leave it.
Ciki
I only notice without battery that C7126 CHGR_BGATE voltage is fluctuating from 8.5V and 1.2V ,with battery is stable 8.5V
Ciki
Resistance between 27-28 is 21omh and 17-18 is 4omh and voltage on pin 2 is 19.6v using 85w magsafe
