Have a Macbook Air 820-3437 here with battery charging and battery power issues. The battery will not charge and the computer will not run off battery. If loaded into the OS, it says "your battery needs to be replaced". I replaced the battery, now it just says no battery is installed (but it still gives the battery percentage at 52%!). I don't think it is the battery in this case. The charger shows green then orange.
SMBUS_SMC_5_G3_SCL : Shows activity (also checked for connection to J6950, is fine)
SMBUS_SMC_5_G3_SDA : Shows activity (also checked for connection to J6950, is fine)
PPVBAT_G3H_CONN : Initially shows around 3V - 4V, but then drops to 0V after around 20 seconds
SYS_DETECT_L: 0.33V
Not sure what else to try. Other than the battery, when plugged into AC it works fine.
My only thought is with the U5000 or U7100, but visually - they seem fine.
SYS_DETECT_L: 0.33V
