[SOLVED] Macbook Pro 15" Retina A1398 POST only in SMC mode
Davis
Got this very dirty machine that gives no POST and off corse remain in black screen, I cleaned it up also with IPA can't see any corrosion or damaged components but still run only in SMC mode then I'm guessing its is an issue with the SMC but how do you troubleshoot SMC issues?
The heating did the trick though no boot on ssd so i turned it off and reset smc and its back to no POST once again..
Got it done after heat on SMC and GPU (probably crap) works fine the last two hours...thanks a lot guys!
