[SOLVED] No Back Light 820-3332 water dmg
Status
Not open for further replies.
Aldizi
U9420 Had Corrosion. Notebook was not powering on after ultrasonic. Powers up no back light. No signs of corresion anywhere else. Pin 1 on connector looks red but soldered on c9000 is reading at 54v
Dont have this lcd im guessing next step order an lcd and try it out? Will a retina 13 lcd work i have those in stock? This is a 15 inch retina but connector looks the same.
At this point you need a known good LCD. This is why you keep a few cracked but working assemblies for testing. Make sure the connector on the board is good before plugging in your good LCD or the cable may burn again.
@Duke Hey been a little busy... Forgot to update so 54v on Pin 1 is no load detected from LED's This was the case as the new Retina display lit up perfectly!
Status
