[SOLVED]No PM_SLP_S4_L 820-2849 - liquid
Status
Not open for further replies.
G.Beard
Corrosion to / around:
J5731, J5800, U3500, VR5020
With Real 85W Charger - Voltages:
PPBUS_G3H = 8.4V
PP5V_S5 = 5V
PP3V3_S5 = 3V3V
PP3V42 = 3V42
PM_SLP_S4_L = 0
What tells the PCH to send out PM_SLP_S4_L please?
Anything obvious I should check too?
Get green light on MagSafe?
Switch to amber when battery connected?
Post SMC_ADAPTER_EN, PM_BATLOW_L, S5_PWRGD, PM_RSMRST_L,
Also check PCH's RTC signals...
Green / Orange = Yes
SMC_ADAPTER_EN = 3V4
PM_BATLOW_L = low / 0 - with / without batt
"S5_PWRGD" ..... Do you mean S5_PGOOD (s)?
Hold up. Just plugged battery and charger and after maybe 5 minutes it powers. It does this even on a fully powered battery. With MagSafe and battery it will power after being plugged for 5 minutes. This is an Apple charger 85Watt.
Power button is non responsive, will check if it pulls low.
Just ran wire from KB connector to ONOFF_L and it's now powering.
I just got this one from Amazon on Sat..... I'll have to order another as I sold my chargers with machines. You think it could be a fake?
The machine STAYS powered with just charger if I connect batt, power on and remove batt, but will not actually power on from cold with just charger. Any idea?
Yes you probably got a fake Chinese garbage charger. Go in About this Mac and see in the power section the wattage of the connected charger.
AC Charger Information:
Connected: Yes
Wattage (W): 85
Family: 0x0085
Serial Number: 0x0002ee49
Charging: Yes
It's not a box of air and it is powering an 820-3332 just fine.
Who knows, I need to buy more chargers anyway.
Status
