ssd Nand ic
tech
Which programmer is good for SSD nand upgrade in macbook models after 2018.
And is programmer required to change nand ic?
If you can pick the NAND from same model donor board, it will work directlly in the same position.
In case not exact donor available, then need P13 programmer.
Be aware, people reported that it can't do the black NAND chips, just the grey ones.
