stuck on apple logo a2141 820-02037-a
larrysito007
was liquid damage and i did a ultra sound on the left side ( so if laptop normally on front of me as in the chassis)just the wing area and it started up but it is just stuck on apple logo and no progress bar
the washed side has no usb-c connector as it was burned but i will put there a new socket once this is working
the ssd-s are not shorted
there is no usb connection as did try external keyboard and others but nothing
the caps-lock is not working at all as light not coming on
there is the 1,8v for the keyboard i tested that (did try other working chassis)
i think something is holding the communication bus but not sure what next
please advice
thank you
Try to start in boot menu.
Just to see if keyboard reacts on start-up.
You can also test, with machine turned off, if turns on pressing any key, or clicking trackpad.
If you detect any reaction, may be good to test it starting in safe mode also.
Sometime, T2 machines stuck on logo, or boot looping, can be recovered with DFU restore.
Be aware, restore will erase SSD.
