Tips for Hakko FM-2027 and FM-2032
spakhnyuk
I use a Hakko FX-951 soldering station with a FM-2027 iron and currently only have one tip at the moment...the bent conical T15-J02.
I am considering purchasing the FM-2032 micro pencil and the following tips today:
Tips for 2027
T15-ILS (conical) or T15-I
Tips for 2032
T30-I (conical)
T30-J (bent)
T-30KN
[FONT=Verdana, Arial, Helvetica, sans-serif]Can you guys give any recommendation and share what tips you like to use?
These will be used for MacBook board repair.
[/FONT]
D_R
Hmm.... in my opinion no one is using a conical tip. I use a chisel tip. With it I also can solder fine pitch without problems. I think, you should watch Dave Jones (EEVBlog) Videos about soldering. In his videos, he explains why the conical tip is not so practical. Currently I'm trying to switch from the chisel top to a blade. It's a much larger tip with a massive thermal mass and it can keep a lot of solder on the blade.
spakhnyuk
Are you sure about the tip? It has a 5mm "blade", I think it's too much. I use the JBC C245-907 tip.
http://www.jbctools.com/c245907-cartridge-chisel-22x1-product-339-category-4-menu-70.html
And the tip I'm trying to switch to is the C245-939 tip:
http://www.jbctools.com/c245939-bevel-edge-tips-product-429-category-4-menu-70.html
You might compare the secs to find the right tip from Hakko.
You have a good point. I do want to have the 5mm tip if I ever need to work on something with larger components than a MacBook board...but I think I'm gonna pick a 2mm chisel tip as well.
Thanks for the insight!
aprendiz
Moderator
No Title
Here my tips...
From left to right:
T15-D52 for big jobs
T15-K Never used, just in case.... lol
T15-1401 For cleaning on reballing process.... also have T15-1402 for bigger chips..
T15-D24 Standard tip almost for any job but no for QFN soldering..
T15-BC28 The most used tip for me, this thing can solder anything...
T15-JL02 For small soldering...
Crizz
[/FONT]
I started exactly like you with only one TIP T15-J02
Your next choice should be a knife TIP like T15-K / T15-KU
It has the ability to solder fine joints with the front tip but you can also use the side of the tip for bigger joints since it has a great thermal mass!
I like to work on QFN packages with it.
Furthermore you can buy used tips here:
http://www.ebay.de/itm/151983745581?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
The seller has al lot of used Tips in stock and he ships world wide :)
