U7000 CHGR_BGATE to Q7055 12v insteadof 5v
mdc2018
Q7055 Output (Pin 5) 11.29V
Everything works on machine, just does not recognize or charge battery
Should I Replace U7000 or should I check other things first?
Didn't think this could be the result because the battery is not proper recognized?
Why should U7000 enable Q7055, if doesn't see the battery???
Check resistance to ground on SCL/SDA lines of battery bus.
And, as general rule, tell us which board you have on the desk...
Do NOT measure continuity (diode mode) on a powered board again!!!
That is completely useless...
I asked about SCL/SDA lines only; means pins 4 & 6 of J6950.
Diode mode should have 3 digits after 0...
Measure discnnecting everything from the board; leave only magsafe connected.
Post CHGR_A/BMON voltages, with both charger and battery connected.
Please, do NOT quote an entire post which is visible 5cm above...
mdc2018
I learn something new everyday -- thank you.
Pin 4 Diode Mode - .502
Pin 6 Diode Mode - .524
CHGR_A/BMON voltages, with both charger and battery connected:
CHGR_AMON - .339V
CHGR_BMON - .068V
mdc2018
After Removing D6950:
Pin 4 Diode Mode - .500
Pin 6 Diode Mode - .522
- Battery Still Not Detected
Given the similar readings should I reinstall the D6950?
& Should I begin to chase down the cause of .522?
Strange that difference now.
There is only SMC remained.
Try first to reflow SMC with good flux; trying to eliminate any crap under SMC.
Hard reflow, SMC balls must melt, as measure points to bad solder on SDA line.
If doesn't help, change SMC...
Normal values change, depending what you have soldered on these lines.
If all components are present, should be aprox 400-450; equals on both lines.
Every time you remove something (for testing purpose), values increase; but should be equals...
mdc2018
Okay -- I reinstalled the same D6950 but left the ISL6259 removed. New readings are:
Pin 4 Diode Mode - .530
Pin 6 Diode Mode - .620
Does that mean anything or are we still looking towards the SMC as the issue?
Once you remove a component from that bus, doesn't resolder it yet, untill you get correct values.
Test every time you remove something.
If need to replace SMC, check the values after solder it; before resoldering anything else
Then resolder components one by one and check everytime the values.
mdc2018
Okay , and just to confirm by correct values you mean same values on pin 4 & 6?
Not necessarily 400-450 until everything is connected normally.
Also just wanted to say thank you for all your help thus far - very much appreciated!!!
Readings are different using different multimeters, even in the same board.
One multimeter will also show different values from board to board.
But in the same board, these two lines should show the same value, measured with the same multimeter.
Usual difference is smaller than 0.5-1%...
